Ct-e sc stage 2 map tolerance
Sprt_inj09
Post by Sprt_inj09 »
I am purchasing a ct e stage 2 sypercharger kit soon. I will be using my flash pro to apply the hondata ct-e stage 2 map. The online specs for the map state stock exhaust, headers, and ct-e intake. Will the map be able to compensate for a skunk2 alpha header no cat with a mega power exhaust and Injen cai without running too lean under full boost or will it have to be tuned? I will be getting a tune eventually after the install.
Re: Ct-e sc stage 2 map tolerance
It is impossible to say. You will have to check the AF and see if it is safe and then tune accordingly.
gabriel223
Post by gabriel223 »
Hello All,
Is there any better CT stage 2 calibration than the current stock one? I'm looking for a bigger power increase in the current CT stage 2 stock calibration. Running about 300+/- hp now, but I really need more power to compete with the big boys (ie, 335i Stage 1 etc..) Any tips? The current A/F ratio on my wideband gauge is under 10.0 at full throttle throughout the whole RPM.
Can I pay Hondata for a service to create a new calibration for me? Please advise. Thank you.
Sprt_inj09
I had a bunch of issues with my ct map so I went through Etunez.com. Did a excellent job and it's cheaper than an actual tuner. Power wise a stage 2 kit wont put you any higher than 300whp unless you get a aftercooler or meth injection. You can do some throttle body and spacer changes that might get you a little more power 5-10hp.
YOu should take it to a shop with a dyno and get it properly tuned for your modifications.
