New to k-pro need help
jeff00ctr
Post by jeff00ctr »
Hello,
I just got my ecu back from hondata just yesterday....I first had troubles downloading the drivers onto my computer so it wouldnt even connect..so I manually downloaded the drivers it my kpro finally went on line...so I go to turn my key to the on position and as soon as I do it continues to go from on line to off line on line to off line back and fourth...I cant get it to keep a constant connection to upload a base map....my cars been running since november so I dont believe its a wiring harness issue...Any thoughts!! if it matters its a k20a type r in a 00 civic ex on running k-pro w/ windows 7 on my laptop
Re: New to k-pro need help
Try the ECU in a known good vehicle as this is most likely a wiring/ground issue. If there is a problem with the wieing you may damaged the ECU or the K-Pro so do not continue to try this in this vehicle until it has been tested in a known working vehicle.
jeff00ctr
Post by jeff00ctr »
I just dont see it being a wiring problem its ran for 4 months prior fine no issues...Really starting to think its a driver issue because I dont even see it in device manager it comes and goes
Why was it sent in for in the first place?
jeff00ctr
Post by jeff00ctr »
i sent it in so it can get k-pro it was a original stock prc ecu b4 i sent it in
jeff00ctr
Post by jeff00ctr »
figured it out......I hate you windows 7
Ctr-asch
Post by Ctr-asch »
jeff00ctr wrote:figured it out......I hate you windows 7
I seem to have the same problem with an '02 prb ecu. What was the problem with windows 7?
jeff00ctr
Post by jeff00ctr »
not sure not good w/ computers go figure so i go and kpro my car lol....my tuner sent me this I downloaded it and it worked
www.moates.net/zips/CDM20814_Setup.exe
hopes this helps you
