tps cal issue
Jaykosi
tps cal issue
Post by Jaykosi »
ok so have a k20z1 in my eg hatch with the hybrid harness when i go to calibrate the tps it read -5for minum reading and 60 for maximum but when i go turn on the car i dont get a tps reading also the car turns of at wide open throttle what can it be the tps looks good and connection also .Another thing i notice is that when i disconect the tps i get the same reading even though i reset the calibrations????what can it be
Re: tps cal issue
Reset your TPS calibration. Check what the TPS reads with throttle closed and then open. If it is only reading 60% fully open you have a TPS problem.
Jaykosi
Re: tps cal issue
Post by Jaykosi »
if i dsconect the tps it gives me the same reading -5minimum and 60 max is like is nt even reading the tps
Re: tps cal issue
How are you getting any readings if the TPS is disconnected?
Jaykosi
Re: tps cal issue
Post by Jaykosi »
i dont know is know
looking for some help.
i cant get my car to run properly.
It basically finished and idles fine, at around 1000rpm after i cleaned the IACV as it was surging.
Now the problems seems as if the TPS has gone, but im not 100% sure and have read a load of threads on it.
I have taken a reading at connector A pin 15 red/blk with ign (II) and with throttle closed i get about .5V and with it open around 4.5V so it seems ok....
However when I run the car and say hold the revs at 3000, it goes up to 3000 for a second then drops back down to around idle range of about 1000 for a second then goes back up, repeating the process.
Ive ran it with K pro connected and whatever position i have the throttle on, weather it is closed, half or open, under the sensors tab in K pro, TPS reads at 0%.
Under parameters> Knock / tps> scale tps, when i click on read for both the min and max values, it comes in at :
minimum reading -5 %
maximum reading 60%
tried to change these readings pressing the throttle but it doesnt change.
checked logic grounds on that ecu plug and both are fine.
I tried my friends TB and TPS with no luck, i cant even get a reading off the ecu plug for his TPS.
thanks
Re: tps cal issue
Try your ECU in a known good vehicle.
robertschultz1
Re: tps cal issue
Post by robertschultz1 »
I am having the same exact issue as the OP. I have been through 2 K-tuned TPS's and still getting the same issue.
Re: tps cal issue
Spunkster wrote:Try your ECU in a known good vehicle.
hondajim
Re: tps cal issue
Post by hondajim »
I'm getting the very same isue on my v3 s300 works fine on my h22 swaped eg civic (obd1) but i get the 5%min 60%max
isue on my 97 crv turbo (obd2) using a jumper harness with no fault code
I notice I have brought the obd2b to obd1 harnes and there is a obd2a to obd1 option available to buy I wonder if that is the isue I'll get one and try
Swapshop
Re: tps cal issue
Post by Swapshop »
Yes I’ve seen this issue too and I couldn’t figure out. TPS was fine and still is, but in the middle of uploading a tune and my laptop crashed/battery went dead, and when I tried again to upload the tune , it seemed like if the connectivity is now off somehow. It uploaded the tune, but the fuel pump prime isn’t the same as before, it don’t prime till a few seconds later, also I have the o2 sensor disabled with the heater checked to off also , and I’m getting that 0%-60% TPS scale issue, I can’t change this value no matter what. Unless I reset it, and yes the ecu is on and online like how I’ve always done it for years. Even if I upload a fresh file tune from the drop down menu if I scale the TPS.. it go’s to the 0%-60% and the 3k limp mode .
How do I fix think spunk ??
Re: tps cal issue
Swapshop wrote: Sat Dec 05, 2020 2:13 pm Yes I’ve seen this issue too and I couldn’t figure out. TPS was fine and still is, but in the middle of uploading a tune and my laptop crashed/battery went dead, and when I tried again to upload the tune , it seemed like if the connectivity is now off somehow. It uploaded the tune, but the fuel pump prime isn’t the same as before, it don’t prime till a few seconds later, also I have the o2 sensor disabled with the heater checked to off also , and I’m getting that 0%-60% TPS scale issue, I can’t change this value no matter what. Unless I reset it, and yes the ecu is on and online like how I’ve always done it for years. Even if I upload a fresh file tune from the drop down menu if I scale the TPS.. it go’s to the 0%-60% and the 3k limp mode .
Have the capacitors been replaced in the ECU?
Lookout22
Re: tps cal issue
Post by Lookout22 »
Did anyone ever get any resolution to this? I’m having the same problem.
Ek92many
Re: tps cal issue
Post by Ek92many »
Im having this issue with P28 HD S300 v3, the sensor checks out with dmm. Hondata simply will not read the tps. I get -5 and 60
elbowspink
Re: tps cal issue
Post by elbowspink »
Did anyone ever figure this out? I am having the same issue with my p28 with fresh caps.
Contella
Re: tps cal issue
Post by Contella »
may be of help...
viewtopic.php?t=22363
