Looking for Basemap for built h22 using Id2000 injectors e85
patroick67
Post by patroick67 »
Well I have tried about everything to get my engine to start, I just can't get the injectors to squirt fuel. Resister box has been removed, and I tried a Basemap for a car running e85 and id1000 and it didn't work I have ignition from my CPR, I am however getting code 6 on s300 I don't know if this is causing the no start or the Basemap so I am trying to find a base map to give it a shot and see if it'll work any advice would be great
patroick67
Re: Looking for Basemap for built h22 using Id2000 injectors
Can't get it to idle by itself and when I try to rev it, it will just die
Resolve the error code first then see how it goes from there.
patroick67
I installed a fuel pressure gauge, turned out to be a bad fuel pressure regulator, with alot of sensors unhooked it fired up after it was replaced. So tomorrow I am going to hook everything up and go from there. I messed with hondata for like 15 mins and got it to idle :D
stevenson_18
Post by stevenson_18 »
Do you still have the basemap for the id1000s running e85 for an h22 or a link to it? Im looking for a basemap for the same thing to get my car idling?
