Switched 12v feed for boost controller
wildjames123
Post by wildjames123 »
where are most people taking there 12v feed for their boost controler from?
Re: Switched 12v feed for boost controller
Switched 12v from the fuse box is best.
wildjames123
Engine bay or incar? is there any polarity of the solenoid directional, or will it work either way and do you splice the diode on literally on too each wire coming out the solenoid. Thanks
THe under dash fuse box. There is no polarity on a solenoid. Do not use any diode with the solenoid.
wildjames123
Ok thanks, but how come there was a diode supplied with the solenoid?
It must be an older solenoid. We now no longer recommend using the diode.
sr420det
Post by sr420det »
Damnit i worked hard putting the diode in, y do u not recommend it anymore?
It interferes with the resolution you get from the solenoid.
lowblow
Post by lowblow »
Spunkster wrote:It interferes with the resolution you get from the solenoid.
So you mean NO more diode for all solenoid?
correct
