Smanager 2.0.0 Bug Out of memory Exception
WickedCivicNY
Post by WickedCivicNY »
Hondata please research:
Version 2 Board - Stacktrace error message, Out of Memory Exception is encountered trying to download calibration. Also tried three different laptops with Windows 7 & Smanager 2.0.0 same issue and smanager crashes after error message comes up
File attached
Re: Smanager 2.0.0 Bug Out of memory Exception
Not a bug, but a limitation of the amount of memory available to a 32 bit windows application.
WickedCivicNY
What is the workaround ?
I tried it with 3 different clients on Windows 7 and cannot access/download the stored calibration.
What is the serial number of the s300 that is inside the ECU?
WickedCivicNY
Customer states - S300 R12 - 2006
WickedCivicNY
You guys find anything ?
That is not a serial number. The serial number is on a sticker.
WickedCivicNY
Spunkster wrote:That is not a serial number. The serial number is on a sticker.
Thats what I thought also... Correction the # on the reflective sticker is #20006
WickedCivicNY
Any ideas what i could try.. its been a few days and I need to access the tune stored in the ECU. The owner does not have his saved calibration unfortunatley.
How exaclty are you trying to download the calibration and what exactly are you clicking?
WickedCivicNY
Connect laptop to Hondata via USB - Go to Online, select Download. The moment when i hit download the memory error comes up.
WickedCivicNY
Anything guys ?
Try closing all the windows inside Smanager when downloading.
