What Spark Plugs do you use with CPR Kit?
H22srv
Post by H22srv »
What spark plugs are you guys running with your CPR Kits?
hondatechpr
Re: What Spark Plugs do you use with CPR Kit?
Post by hondatechpr »
I use BKR8EIX
ef9b16a1
Post by ef9b16a1 »
resistor type , i guess ngk (R) if u use ngk
anyone use NON-resistor ngk plugs without having break out issues with the cpr?
Never, ever, use non resistor spark plugs. There is no advantage and significant disadvantages.
El Verdugo
Post by El Verdugo »
Okay so can one get away with a BKR8E the copper style instead of the Iridium version?
rev hard
Post by rev hard »
will the bkr8e work?..or do they need to be bkr8eix ?
It does not matter as long as they are resistor type plugs.
