B16 greedy map safe?
wildjames123
Post by wildjames123 »
Hey iv got a b16a2, 9:1cr cp pistons, eagle rods, rc750's, gt35r watercooled turbo, walbro fuel pump, 1.5mm cometic head gasket, arp head studs..
iv mapped the car so underboost the af is 11.9 i am only running the car to 8psi at the moment. I am curious to know how safe/good the ignition table are on this base map as i have left them unchanged. Can i boost too 14.7psi with out the risk of knock.. i am in the process of getting the car to a point where i will do a proper tune Thanks
Re: B16 greedy map safe?
Only you or a tuner can determine if it is safe and not detonating.
