KManager V3-1-1 (beta)
This is a release of some new features before the start of the drag race season.
Quickspool
Holds the wastegate shut until just below your target boost.
Burnout Rev Limiter
Push button activated rev limiter for ... burnouts.
Test Upload
For dealers installing KPro V3s, so they do not need to register the KPro in order to test the install.
V3.1.0 Changes
  • Added grouping and right justification to the Sensor Window.
  • Added a form to change and create shortcuts.
  • Added a quick spool table to the boost control parameters.
  • Added a test upload function under Online->Tools->Test Upload for performing a test upload in newly installed KPro v3's without having to register them.
  • Fixed launch control malfunction where lean protection cuts injectors when they are both enabled.
  • Added a burnout rev limiter.
  • Changed Check For Updates to show current version number and release dates for both beta and production releases.
V3.1.1 Changes
  • Fixed Conversion exception when checking for updates with non-English language settings
