Posts: 10652 Joined: Thu Aug 15, 2002 12:13 pm
Post
by Hondata » Wed May 02, 2012 8:57 am
Speed Limiter
Useful for people who must stay under 135 or 150mph at the drag strip.
Quickspool
Holds the wastegate shut until just below the target boost to spool the turbo quicker.
Test Upload
For dealers installing S300 V2, so they can test the upload / datalogging without needing to register the S300.
V2.1.0 Changes
Added speed limiter .
Added a quick spool table to the boost control parameters.
Added a test upload function under Online->Test Upload for performing a test upload in newly installed S300 v2's without having to register them.
Changed Check For Updates to show current version number and release dates for both beta and production releases.
V2.1.1 Changes
Fixed Conversion exception when checking for updates with non-English language settings
FreshDA9
Posts: 252 Joined: Sun Jul 27, 2008 8:40 pm
Post
by FreshDA9 » Wed May 02, 2012 9:25 pm
is the quick spool table in duty cycle or psi?
EFI-101 & Advanced Certified*
FreshDA9
Post
by FreshDA9 » Wed May 02, 2012 9:27 pm
O sorry it says pressure
Johnny_9
Posts: 312 Joined: Sun Apr 09, 2006 5:12 am
Post
by Johnny_9 » Thu May 03, 2012 7:44 am
great to see an update on s300; hope to see more feature requests soon.
FreshDA9
Post
by FreshDA9 » Thu May 03, 2012 8:47 am
Johnny_9 wrote: great to see an update on s300; hope to see more feature requests soon.
X2
Still hoping for serial logging support for widebands! would like to retire my obd-1 harness and use my lm2's usb.
Plus other request in the request page!
Post
by Hondata » Thu May 03, 2012 9:23 am
Wideband serial datalogging is supported if you have a s300 v2.
FreshDA9
Post
by FreshDA9 » Thu May 03, 2012 9:08 pm
ahh i didnt see it under the digital tab. i take it S300 v1 hardware cant support this?
Posts: 24147 Joined: Fri Sep 20, 2002 5:06 pm
Post
by Spunkster » Fri May 04, 2012 9:23 am
correct.
jiggacivic
Posts: 35 Joined: Wed Oct 08, 2008 12:55 pm
Post
by jiggacivic » Sun May 06, 2012 7:33 pm
tried out this version today and it does not pulse the boost solenoid it just keeps open and PWM says 99% reverted to version 2.0 and it worked as it should.
Post
by Hondata » Mon May 07, 2012 7:51 am
Check your quick spool boost table - it probably has pressures higher than your normal boost.
jiggacivic
Post
by jiggacivic » Mon May 07, 2012 10:41 am
in the car sitting and did change quick spool to 0 kpa but solenoid just clicked no pulse.
Post
by Spunkster » Mon May 07, 2012 1:23 pm
What do you have the activation pressure set to?
jiggacivic
Post
by jiggacivic » Mon May 07, 2012 2:37 pm
activation is 0 kpa here is a copy of the skl
Test.skl
Post
by Spunkster » Mon May 07, 2012 4:21 pm
It should not activate under vacuum. If you are using kPa, then set the activation pressure to 108kPa. Then set the Quick spool presure to 120kPa.
nayr_one
Posts: 35 Joined: Mon Mar 31, 2008 8:49 pm
Post
by nayr_one » Tue May 08, 2012 11:15 pm
whats all this traction control stuff in the sensor setup window is this functional yet or just in here till you get the actual version 2.1.0 done?
