Obd1 or Obd2A (or Obd2B)
Bubleguy
Post by Bubleguy »
Hi,
i've built a turbo civic EF9 on my own, tuned it(using hondata) with a P28 (obd1) with s300 card inside.
I recently bought an Honda Integra and i was wondering if i should use my" p28 with a harness convertion" or "use the p72(obd2A) with the s300 card pluged inside".
According to this article : http://www.hondatech.com.au/forum/showthread.php?t=188
it seems there is no main change, so keeping the p28 would be fine.
I didn't find any other good article, but it's a bit strange that they(engeneer/manufacturer) created recent ECU (obd2A obd2B) if there is no performance increase from CPU, condensator, diode, bandwich etc ....
So i need your feedback about micro-processor performance on the newest ECU.
Should i keep my p28 or should i use my p72 and plug s300 card in it?
Many thanks,
Bubleguy
Re: Obd1 or Obd2A (or Obd2B)
The difference in the ECUs can be found at http://www.hondata.com/ecus.html It is completely up to you which ECU you use. It all depends on what options you want the ECU to be able to use.
Bubleguy
Post by Bubleguy »
Well, if i understood your link, the p72 can manage knock sensor and IAB, but as i don't really care about them(cause i've no knock sensor on the engine), i can stay on the P28.
It seems there is no improvment of CPU frequency, no improvment in data calculation...etc.
Thanks for your help mate.
Bubleguy
Hermanmax88
Post by Hermanmax88 »
can you even install an s300 in an obd2a ecu?
The s300 can only be used in an OBD1 ECU.
