R18 civic w/small turbo kit goes mega rich under boost
wiggum80
Post by wiggum80 »
2009 Civic with R18 turbocharged. All is well until boost, when it crosses over from the last vacuum column it goes 10.0AFR no matter how much fuel I remove. Any ideas or suggestions will be much appreciated.
Re: R18 civic w/small turbo kit goes mega rich under boost
wiggum80
Post by wiggum80 »
serial #
fp-r18-us-50163
flashpro manager version 1.2.8.0
calibration
civic r18 rna 7 tsi
2009 civic dx 2dr r18
stock ecu - not original from vehicle
37820-rna-a09
modifications
t28 journal bearing turbo
2.5'' exhaust with 4'' tip turbo back no cat just resonator
injectors 410cc rdx
motor mounts (boomba)
hks mushroom filter
2.5'' intake piping
2.25'' charged air piping
intercooler28x8x2.25
You have a lot of error codes. Resolve those then see if the problem goes away.
wiggum80
Post by wiggum80 »
Hmm.. well I cleared the codes and drove the car for 2 days back and forth from work. I didn't go into boost and the mil light didn't come on at all. As soon as it sees boost I get MAF malfunction code and system too rich code. Any suggestions as to what step I should take next? Any direction is much appreciated, thanks for looking at the datalogs.
reaperdwarf
Post by reaperdwarf »
I had the same problem, I had this problem because the MAF was to close to the fans and when they went on i got the malfunction, I changed to map based tuning and moved the MAF after the intercooler and this fixed it
