S300v2 2 different maps/tune possible?
Dc4LsTeG
Post by Dc4LsTeG »
I searched and couldnt find the answer. Can you run 2 different tunes on the v2 say one for street/pump gas and the second for track/meth injection? If so how would you change between the two? Or would I have to have 2 different calibrations and upload each one to the ecu everytime I wanted to switch it?
Re: S300v2 2 different maps/tune possible?
You can use secondary tables for this: http://www.hondata.com/help/smanager/se ... ary+tables
Or you can just upload a different calibration for the different conditions.
Dc4LsTeG
Post by Dc4LsTeG »
Great info thank you. So I can run the two different maps and have them toggle back and forth with using a switch?
correct.
Dc4LsTeG
Post by Dc4LsTeG »
Can you tell me how youd wire it? It sounds kind of confusing to me if you could please explain how you can load the different maps with the flip of a switch. Thanks again for all of the help as you can tell im a noob when it comes to Hondata
Details on the switched inputs can be found at: http://www.hondata.com/help/smanager/sw ... sub=inputs
Wiring depends on how the input is triggered, 12v or ground.
Dc4LsTeG
Post by Dc4LsTeG »
Thanks I know how/what to wire the switch to but I guess my question really is, how by hooking up a switch does it change between the two maps? Say when the switch is off im using my main tables but if I turn the switch on it changes it to my secondary tables?
The ECU sees the input change and runs based on the setting for that input.
Dc4LsTeG
Post by Dc4LsTeG »
Ok now I see thanks alot!
