recovering info from the hondata ecu
leron
Post by leron »
hello i have a hondata ecu s300 from another integra with a b18c engine as mine, both cars are turbo applications. how do i find the info pertaining to the settings of this ecu before i am able to use it in my car? i don't know what type of injectors he used and what were his other tune settings. can anyone help with this?
Re: recovering info from the hondata ecu
You can try going to Online, and Download, but this is not recommended. Since tis is a different vehicle, you probably should just go to the new Calibration button and start with a fresh base map and tune it accordingly.
leron
Post by leron »
Both cars are the same,the difference is the injecter size.is there a way to just change just that setting?
You can try but you will aslo need a wideband to get the fueling correct. Injectors have different flow rates at different pressures and voltages. This is not something you can compensate easily for by changing one parameter.
