FlashProManager V1.3.3
2009-2010 TSX Support
Quickspool
Holds the wastegate shut until just below the target boost to spool the turbo quicker.
V1.3.0 Changes
  • FlashPro firmware updated to version 45
  • Added support for the 2009-2010 TSX.
  • Added long term fuel trim min/max to closed loop parameters.
  • Changed Check For Updates to show current version number and release dates for both beta and production releases.
  • Added quick spool to boost control.
V1.3.1 Changes
  • Fixed Conversion exception when checking for updates with non-English language settings
V1.3.2 Changes
  • [S2000] Added minimum ignition timing tables.
V1.3.3 Changes
  • [Civic Si / CTR] Added VTC deceleration angle control.
    [Civic Si / CTR] Added gear ratio correction for ECU gear detection as well as cruise control.
  • [Civic Si] Added boost cut, fuel overrun cut delay, second ECT sensor, VTC cam angle index.
  • [Civic CTR - Euro] Increased maximum cam angle to 50 degrees, added warm up retard table.
  • [S2000] Changed P2A00 error threshold.
mabo
Re: FlashProManager V1.3.1 (Beta)
Post by mabo »
Very RAW release.
First, i still see 1.3.0 on top after i installed 1.3.1,
it constantly shows error
It still show 1.3.0 in check for updates and after i press download 1.3.1 it throws error - update.exe isnt win application.
IcEMoCHa
Post by IcEMoCHa »
Unable to open any calibrations using this version.
VaporBomb
Post by VaporBomb »
I am getting the same error. I also cannot open any cals. This was my first install, and I have uninstalled it. Should I try to reinstall v1.3.1, or is it ok to just download v1.2.8?
Thanks for any help.
It has been fixed. Try it now.
VaporBomb
Post by VaporBomb »
Spunkster wrote:It has been fixed. Try it now.
Seems fine now.
mabo
Post by mabo »
Works fine , thanks guys. Please dont pull out old one before you see new one is working )
beaugus
Post by beaugus »
In regards to the recent addition of "Added long term fuel trim min/max to closed loop parameters" - does this adjustment allow us to virtually "disable" long and short term fuel trimming on MAF/MAP hybrid calibrations by making the values "0" and if so are there any significant concerns by doing this?
My FN2 is running a hybrid MAF/MAP tune at the moment and the fuel tuning is virtually flawless but the short and long term fuel trimming is affecting my tune the longer I drive and have been waiting for the option to disable fuel trimming and hoping this new option finally allows me to do this.
Just wanted to be 100% sure before I commit to making changes to my tune that I'm correct in saying that changing the values to 0 will esentially disable short/long fuel trim whilst in closed loop.
mabo
Post by mabo »
mabo
Re: FlashProManager V1.3.2 (Beta)
Post by mabo »
i had 1.3.1 on second PC , selected check for updates option , pressed download 1.3.2 ang got this
Not shure latest build have this error but i cant check it )
Anti virus software is removing the update.
mabo
Post by mabo »
Sorry but its not an a-virus tricks. Its system error, before i posted i tried it on clean VM and disabled antivirus on regular system and got same error.
Then use explorer to check the update.exe file in your User directory, and see if the file runs directly.
Try downloading the update directly from the downloads section of our website.
mabo
Post by mabo »
Hondata wrote:Then use explorer to check the update.exe file in your User directory, and see if the file runs directly.
I tried , this file is zero length ( 0 bytes ) and i cant open it, same error. I disabled a-virus and reinstalled manager , same result.
