A/F Active on in-gear deceleration
Slip_Angle
Post by Slip_Angle »
Noticed today on my Tunerview II that when decelerating (in gear) my A/F was jumping around. The injectors should be off with A/F stuck at 32.x from what I understand.
This evening I took the car out to datalog and checkout the problem. Normally A/F would show 32.x as the injectors are off and most of the time it did but there were a couple times when it showed 22.x - These are in the datalog. I'm not sure if the problem exhibits itself more in the heat but I couldn't totally reproduce it.
Also, at 12:50 you can see the TPS drop out for a moment. TPS issue?
Also: Is it normal for MAP to be 97kpa when the car is off?
Kpro Serial #2547
KManager 3.0.3.0
2002 Civic SiR (Ep3)
K24a2 swap - This was done 4 years ago.
2012-05-05.kal
2012-05-10-trouble-short.kdl
Re: A/F Active on in-gear deceleration
I think your two observations are related. The TPS is definitely dropping out (there's 4 occurrences in the datalog), but the TPS might also be going open upon overrun, and the ECU would start the injectors again. This sort of thing can happen at a higher rate than the datalog, so you don't always catch it. The only other thing I can think of is the overrun cutoff MAP pressure, which needs to be lower on K24s, but this usually gives you a jerky light throttle effect.
I wish Honda offered the TPS as a replacement part.
Slip_Angle
I replaced my TPS with a new one from K-Tuned and I still see the drop outs...although there seems to be fewer.. What to try next?
Check the wiring for corrosion or bad grounds. Use a multimeter to check the for resistance between the ECU and where they terminate.
