"feed power from main relay to pins 9, 14, 20"
klone
Post by klone »
im having wiring problems with my k swap car and i found the "k20a engine swap wiring" tech article and i want to make sure i have power in these 3 pins but i just want to know the correct way of going about this. (car on car off anything unplugged)
im getting the classic vbu high voltage and the cmp no signal.. i see that 2 of these wires has to do with them and just want to maybe start there and work my way back.
im usuing kpro and a hybrid racing harness
k20a2 motor and motor harness in a 96 civic
thanks in advanced
Re: "feed power from main relay to pins 9, 14, 20"
If you are unsure about how to wire everything, I would highly recommend contacting Hybrid Racing or you may damage the ECU or worse.
klone
Post by klone »
okay, thanks ill try calling them today
just an update : with the ignition on i have power to pins 14 and 20 on the motor harness side but i do not have power to the CMP 9 pin.. i guess thats where that code is coming from but im just not sure how to fix it.. i guess ill just call Hybrid Racing
thanks alot spunkster
klone
Post by klone »
hey spunkster have you every seen this problem get fixed or do you know anything i can try?
everythings wired correctly
if things get worse thats just whats happens i guess. i dont mind..
any ideas from here?
Try the ECU in a known good vehicle. You may have already damaged it.
klone
Post by klone »
okay my ecu is fine in a good car and their ecu still throws the codes in mine...
its out of your hands now kinda right?
thanks
There is obviously a problem in the wiring of you vehicle. Call Hybrid back and tell them the ECU works in another vehicle.
klone
Post by klone »
thank you
