VTC wont command with new 3.1.1?
theblu3marker
Post by theblu3marker »
VTC wont work for me for some reason with 3.1.1. Had to go back to the normal 3.0.3. Just wondering if im the only one experiencing this problem with the new beta?
I have an ep3 with a PNF ecu. To lazy to get the serial number for I am not that concerned about the beta issue. Still works fine on 3.0.3.
Re: VTC wont command with new 3.1.1?
This was tested and is working properly. Close the program, reopen, then upload the calibration again.
Slip_Angle
Post by Slip_Angle »
Assuming the 3.1.2 update was to fix this?
Hondata: Did VTC either fully function or not at all on the PNF? It seems to work fine on my EP3 /w PNF but curious if there were other issues?
Slip_Angle
It doesn't answer my question. Instead of posting a link with no answers, can't you take 2 minutes to explain the issue? As I said, it appears to work on my car so is this under certain conditions? Does it partially work?
I am not aware of it NOT working.
Slip_Angle
Spunkster wrote:I am not aware of it NOT working.
Change History
V3.1.2 (6 July 2012)
• Fixed PNF VTC not working.
Slip_Angle
Is there detail you can provide?
This seems to be going in circles. There was a problem with VTC staying at 0 on the PNF ECU with KManager 3.1.1. This problem was fixed with 3.1.2.
If you have a specific problem running 3.1.2 then follow the posting guidelines and provide the details.
