help where is e21 and e22 located on the k-pro??
rsxtypes209
Post by rsxtypes209 »
hey im trying to wire my power relay 85 to e21 and e22 to my on and off switch but idk which wire on the k-pro is e21 and e22?? i have an 05-06 k-pro harness adapter. and on my power relay #86 i rout that wire to a 12v keyed source?? and where is that located?? also on the on and off switch i wire one wire to the e22 but what about the other wire?? where do i connect it
Re: help where is e21 and e22 located on the k-pro??
What vehicle do you have, and what is the 'power relay' which you are trying to wire in?
rsxtypes209
i have a hella 12v power relay and i found out where the 12v source is located at the ignition wire yellow/black under the steering wheel. i have a rsx-s 05-06 so can i use the power relays 12v keyed source and the on and off switch 12v keyed scource can i tap it on the same yellow/black ignition wire for 12v sourced both of them?? also the number #85 on the power relay i need to splice the wire in the e21 into the k-pro?? but where is e21 located?? is it connecter e 21??? also for e22 i guess its conecter e 22 and connect a wire to my on and off switch?? also where shud i connect the wire on my on and off switch for the e22 wire shud i connect it on the off or on side??
this is for a dry nitrous for k-pro
what about the 12v keyed source on the cigeretted ligther can i tap both my relay and on and off switch there for 12v keyed source??
http://www.hondata.com/techkpronitrousdiagram.html
http://www.hondata.com/help/kmanager/ecuconnectors.htm
There are empty connectors in the fuse box that have switched power.
rsxtypes209
so i wire the power relay #85 to 21vsv of the k-pro harness and 22bksw k-pro harness to the on and off switch correct??
Yes, just wire it as it shows in the diagram
