Afm fuel table
nunoctr
Afm fuel table
Post by nunoctr »
Hi hondata
Sorry for the question, but what is function of the "afm fuel table" on the afm cals.
I can't see any help file on this.
Thanks in advance
Re: Afm fuel table
AFM flow converts the AFM voltage into airflow in mass/time units.
http://www.hondata.com/help/flashpro/tu ... s_flow.htm
nunoctr
Re: Afm fuel table
Post by nunoctr »
Thanks for the fast reply, i know that table and i always tuned my fuel from there.
My question is about the new table "Afm fuel" that have air mass and injector (ms)
Calibration (advanced) - fuel - afm fuel
Re: Afm fuel table
This table?
It converts the cylinder air mass to injector duration which gives a stoichiometric air/fuel ratio.
nunoctr
Re: Afm fuel table
Post by nunoctr »
Yes hondata, that's the table.
When and why we should change the values? Can't you do some help file on this.
I am One of the few fans of afm tuning...
Re: Afm fuel table
For stock injectors you should not change the table. It only really needs to altered with larger injectors and forced induction.
nunoctr
Re: Afm fuel table
Post by nunoctr »
thanks
R-12914
Re: Afm fuel table
Post by R-12914 »
Hi Hondata,
A colleague and I have the problem, that the idle falls down to ~500 rpms if we change gear or press the clutch (only with AFM or Hybrid cals!)
The technical data from both cars are the following:
1. Honda Civic TypeR FN2
2. Rotrex supercharged @10 PSI (forced induction)
3. RC 750cc injectors
4. Exedy Stage 1 Clutch
I have attached a calibration and a datalog of the problem.
Can we fixing the problem if we increase the afm fuel tables?
If yes, how it works, what should we do and what is to be considered??
2008 Honda Civic TypeR FN2
ECU: 37820-RSP-E02
Flashpro: FP-SI-INT-21153
Software: 3.6.1.0
Firmware: 185
Re: Afm fuel table
It is fuel tuning. The tables seem very rich at low load and the AF is going very rich. Part of the problem is the dead times are too low. Also, why is the cam angle zeroed?
R-12914
Re: Afm fuel table
Post by R-12914 »
It is not a finished map but the problem is also present on a final map.
How can i fix the problem?
How can i make the dead times higher?
ECU: 37820-RSP-E02
Software: 3.6.1.0
Firmware: 185
R-12914
Re: Afm fuel table
Post by R-12914 »
My tuner writes, that changes in this table has no effect in hybrid cals?
Also this tables has no effekt in hybrid cals?:
http://www.hondata.com/flashpro_forced_ ... h_afm.html
Why not?
A hybrid cal is is nothing more than a AFM cal with MAP fuel tables!?
My tuner writes both things has no effect on speed density based fueling (hybrid cal).
Is this right or imbecility?
ECU: 37820-RSP-E02
Software: 3.6.1.0
Firmware: 185
Re: Afm fuel table
Assuming you mean the AFM flow and fuel tables then yes, they are not used with speed density.
Why not? Because speed density uses manifold pressure and engine speed for fuel lookup.
R-12914
Re: Afm fuel table
Post by R-12914 »
If we use a Hybrid Cal with MAP fuel tables with the option "Use speed/density (MAP) fuel tables" and the addon "Minimum pressure for speed/denity" with corresponding pressure like this:
Then it is so?:
If we enter a pressure in the field, then we can use AFM (AFM flow and AFM fuel tables) like a normal AFM Calibration, if we are below this pressure (entered in the field)?!
If we are above the pressure (entered in the field), than the ECU switch to MAP fuel tables, so AFM flow and AFM fuel have no longer a influence!?
ECU: 37820-RSP-E02
Software: 3.6.1.0
Firmware: 185
R-12914
Re: Afm fuel table
Post by R-12914 »
Hondata?
ECU: 37820-RSP-E02
Software: 3.6.1.0
Firmware: 185
Re: Afm fuel table
I'm not sure what you are getting at.
