s300/ecu problems.
jdm inc
s300/ecu problems.
Post by jdm inc »
i am having a problem with my ecu with s300 v1 in a 93 honda civic
I cut r2 and r3 for analog input 2 to be used. for a fuel pressure sensor.
and also cut. r136 and r 138 for my wideband
Now when i go to start the car. its getting cel code 9 cyc 1 sensor.
i tried a buddy of mines s300 and bam no check engine light.
what could be the problem?
T1 Tuned 765@34lbs :) pb 9.75@154 fastest mph 155
http://www.t1racedevelopment.com
http://www.youtube.com/watch?v=lRwE0k9MIl0&feature=plcp
jdm inc
Re: s300/ecu problems.
Post by jdm inc »
What ECU is this in and can you post pictures of exactly what you have cut?
jdm inc
Post by jdm inc »
P28 Ecu yes I can take a pic and post as soon as I get home
jdm inc
Post by jdm inc »
Have you tried your ECU in the other vehicle?
jdm inc
Post by jdm inc »
yes tried it in a 93 civic coupe. and still the same thing.
all stock!
jdm inc
Post by jdm inc »
any ideas?
Have you tried the other ECU with your s300?
jdm inc
Post by jdm inc »
no i have not, but i put in another s300 and the check engine light went away
jdm inc
Post by jdm inc »
cutting those resistors out shouldnt have messed up the ecu though right?
and i am afraid to cut them out if i get a new ecu cause i dont want the exact thing to happen.
Those resistors will have nothing to do with that error. Try your s300 in a different ECU.
jdm inc
Post by jdm inc »
can i cut the resitors also correct?
