LAF Voltage to Lambda
GernBlanston
Post by GernBlanston »
I'm curious about the purpose of the LAF Voltage to Lambda table. Does that allow the user to adjust the OEM AF sensor so that it is correct, which would eliminate the need for the AF Corr value? If so, do you have any plans to enable this feature for the S2000?
Re: LAF Voltage to Lambda
Yes, it essentially allows the stock wideband to be re-calibrated. However, the S2000 wideband works in a different way, and it is not as straight forward as the Civic to add the tables.
