Data logging egt's with hondata v2 and aem
TurboSohcRyan
Post by TurboSohcRyan »
Trying to finish wiring for my s300 v2, and I have a few questions. I am trying to use the AEM 4-channel K-Type thermocouple amplifier. Wiring each 0-5v output for the aem to an analog input on the v2, should be all I need right? Or can I use the digital in put like with the plx that can daisy chain?
Another question, Once it is all wired, I am having trouble getting them to read right. Fire up the car and let it idle for a min, the hondata reads like 38* when the cylinder measures 330* with a laser temp gun on the turbo mani? Do I just need to adjust the voltage offset? But where you can adjust the V-offset, it says "if you need to set a non-zero offset, then your analog ground is incorrect." What do I need to check to be sure that is correct?
D16z6-GoldenEagle, AFI Turbo, Precision Turbo, Hondata, CG Racing.
618hp 407tq
10.68@137 Single cammer.
Re: Data logging egt's with hondata v2 and aem
What is the part number of the AEM unit? It may have a different 0-5V output than the 5131 we used.
Don't change the voltage offset. If you need to you can enter a custom conversion, but you will need to conversion calculation from the AEM manual to calculate this.
TurboSohcRyan
618hp 407tq
The 5131 and 2204 have different analog outputs, so you'll need to create a custom conversion.
The formula is Temperature (C) = Volts * 200 so for the custom input set voltage 0 = value 0 and voltage 5 = value 1000. Set the type to temperature and units to degrees F and it should work for you.
