new to s300v2 all 4 injectors stay firing at once why??
PROTO TYPE FI
Post by PROTO TYPE FI »
All 4 injectors fire at same time and stays that after crancking is this a setting or a problem? How do you fix it??
Re: new to s300v2 all 4 injectors stay firing at once why??
What is the s300 serial number and who socketed this ECU?
PROTO TYPE FI
s300 r12 21128 showzone ladson sc did the ecu socket work
Have you uploaded a calibration to the ECU?
PROTO TYPE FI
yes uploaded one closest to my motor im the one with no live data either you told me to check j12 ect. the only info coming across is an0 through an8 just 0-5 volt references
I would recommend taking it back to Showzone and have them check the ECU socketing.
