Car won't start, help!!!
Rsxlemon
Post by Rsxlemon »
I got a 06 rsx s used car with kpro. The flywheel broke, so I replaced new flywheel and clutch. My mechanic tried to troubleshoot the problems,battery good, alternator good, replaced a new starter as well. The car is cranked, no spark, engine lights on, ECU hot, (checked by Hondata tech was good. ) Unable to check engine lights due to OBD does not read any code (no link). what could be the problems? Help
Re: Car won't start, help!!!
What is the serial number of the K-Pro board inside the ECU?
Rsxlemon
Post by Rsxlemon »
#05003452
37820_PRC_023
2070_403709
Stock ECU worked after dealer reprogram, but this Hondata unit did not have any output. Javier checked it out before and stated it ok.
That ECU is not for an 06 RSX and will not work in one.
http://www.hondata.com/kpro0506.html
Rsxlemon
Post by Rsxlemon »
What is your suggestion I should do? Why is this ECU worked at the beginning and didn't work after transmission changed? Should I send it in for upgrade version? How much
does it cost?
We do not convert PRC ECUs for use in 06 RSXs. We only use the ECUs listed on our website.
Rsxlemon
Post by Rsxlemon »
The informations you gave me seem irrevalent, you stated that the ECU series # is not for 06, then for what model? but the previous owner had it operated till I broke the clutch. it came with the blue harness adaptors.
