injector 100% duty- and datalog wont download to ecu?
boostedtech
Post by boostedtech »
have a few questions, ive been resaerching alot on hondata since ive got it and have become pretty fimilar with it. i tuned my lsv turbo on 8 psi on the street with good results, now im on 13.5 psi and my 680cc injectors are showing a max duty on my graph, i was told the car had a 255 pump in it, so i never touched it. also i am running 50 psi fuel pressure, it is a cheaper style regulator. is it possible its malfunctioning under high boost? i was aware that these 680s should do me a little over 400 to the wheels, i dont think im there so im confused as to the duty cycle. im also running a very large top mount turbo, an agp zeta 3.2 wich flows roughly 77lbmin i believe.
on my graph im showing good 11.5 afr up to about 3rd gear 7k then it goes lean and i hit my lean cut that i have set. sorry its alot but i wanted to give as much info that i could.
next my datalogs...
now i can datalog just fine and record and watch everything on the graph just fine, but when i go to down load them to the ecu its showing that there is no space taken up on the ecu. here im just completly lost.
thanks hondata for any help!
Re: injector 100% duty- and datalog wont download to ecu?
Are you datalogging using the laptop and are you clicking the record button?
boostedtech
Yes and yes.
Then you need to save the datalog from the datalog menu at the top. This has nothitng to do with on-board datalogging.
boostedtech
Ok ill give that a shot. Thank you. Any input on the injectors?
Impossible to say without the calibration and a datalog showing the problem.
boostedtech
here ya go
