do i need to put some thermal compund behind IC12 ?
racepak
Post by racepak »
hey guys,
do i need to put some thermal compund behind IC12?
thanks
Re: do i need to put some thermal compund behind IC12 ?
Not necessary. Normally there is a small grey square of material between the voltage regulator and ECU frame.
racepak
Post by racepak »
Hondata wrote:Not necessary. Normally there is a small grey square of material between the voltage regulator and ECU frame.
which material?
thanks
It could be an insulator and/or thermal compound.
The gray thermal material is only used on P75 and P72 US ECUs and all JDM ECUs. They use a different voltage regulater than the other ECUs.
