p06 ecu problem
the_racerx
p06 ecu problem
Post by the_racerx »
hello,
my tuner and I have now connected my s300. My control unit is a p06.
then we have loadet the stock p28 map on it, my car was running in to lean. afr is 16.9 +
then we have connected with his p28 s300 and uploaded the same map and my engine runs perfectly in 14.7
why is my p06 ecu with s300 running to lean? is there a different between p28 with s300 and p06 with s300?
thank you for your help
regard
Re: p06 ecu problem
http://www.hondata.com/forum/viewtopic.php?f=19&t=3772
The only difference between a P06 and a P28 is that the P28 has VTEC. There may be somethign wrong with the P06.
the_racerx
Re: p06 ecu problem
my vehicle is 96 del sol with d16y8. i use a obd 2 to obd 1 harness.
vtec is chipped on my p06 and we testet my p06 ecu with a hondata tester and all led was green.
can it be possible that my s300 is damaged? the lights on the s300 is green.
Re: p06 ecu problem
Put your s300 in his P28. It sounds like a problem with the P06
