TECH EDGE Wideband install with Hondata s300 V2
Blulude98
Post by Blulude98 »
Can anyone please help on how i can connect the following Tech Edge wideband metre : http://wbo2.com/2c0/default.htm to my Hondata S300 V2??
Wiring info for Wideband is here: http://wbo2.com/2c0/schem.htm
Re: TECH EDGE Wideband install with Hondata s300 V2
http://www.hondata.com/techplxwiring.html
Wiring a wideband is just a variation on a theme.
Blulude98
Post by Blulude98 »
Many thanks for your reply Spunkster but are you able to look at the Tech Edge wiring (Side of 2C0)and tell me which wires i need to connect to the input source?
And as i have the V2 S300 Hondata version do i still need to use D10 ELD as a source i can i now use the Digital or Analog channels that are available as a input source?
The digital an analog inputs on the s300 itself cannot be used for running closed loop or lean protection. They are for datalogging only.
You will have to determine what are the outputs on the wideband controller. You may need to contact the manufacturer of the wideband for assistance with this.
