Flashpro for R18 owners/tuners missing Valuable programing
Which do YOU want first?
Poll ended at Thu Dec 20, 2012 8:16 pm
Boost Control Function and editing?
3
100%
Speed cut function?
0
No votes
Total votes: 3
JoshPTS
Post by JoshPTS »
I have seen very few posts about flashing the R18, let alone fewer by the developers.
So why I'm really posting, only two simple questions.
Can you activate the boost control function within the R18 calibration tab for use with the Hondata Boost Control solenoid?
Will you please add the ability to edit the speed limiter? Known as "speed cut" under Rev limits within the calibration.
Thank you in advance for broadening the tuning spectrum.
Diablo Sport, Kpro, Flashpro, AEM EMS, Delta Dash, Access Port, G4 EMS, SCT Pro, Livewire, X3 Power Flash, HPtuner Pro, Diablo tuning experience, still plenty out there.
JoshPTS
Re: Flashpro for R18 owners/tuners missing Valuable programi
Post by JoshPTS »
So, no impact no idea? Over a month and not one clue from DEV?
If I posted this in the wrong section..... no way should of been moved by now for sure.
420Coupe
Post by 420Coupe »
Definitely would be interested in both, do not see why they cannot be implemented together.
Guess we just need to draw more attention to R18's ?
How's this
World's First Sleeved R18A1
4Piston P&P
Boost by gear would be IDEAL for this set up as I have both a new LSD and Final Drive 4.687
We need to get this bumped up on their priority list.
JoshPTS
Post by JoshPTS »
Oh believe you me I know, Looks great!!! It doesn't seem like they even check there forums, return calls, or really care anymore. Whens the last time any of them have posted? Seriously Hondata, slacking just a bit here.
We're here, and do care. Your requests have been noted.
420Coupe
Post by 420Coupe »
Hondata wrote:We're here, and do care. Your requests have been noted.
AWESOME!!!!! here's some more goodies for you guys.
420Coupe
Post by 420Coupe »
A little introduction I will have the progression of the build in chronological order. First is the Turbo kit Build, Second will be Motor build thread. Figured this would give you a tad bit more initiative! :wink:
*Stainless steel Turbo manifold,exhaust,Dumptube
*Aluminum 2.5in Intercooler piping
*Aluminum 3' Inch intake with KN filter
*intercooler
*Tial 38mm vband
*Tial 50 mm blow off
*Precision 5857b turbo
*Walbro fuel pump
*FIC 625cc injectors
*Flashpro
*CMB tuning - by Colombia!
Heres some Pics of the progress, amazing welds !!
:turboleghump::vtec:
FINISHED PRODUCT
Dyno Results were @ 7 psi
Full Motor Build
Engine -
*R18A1 Block
*CP Pistons
*Pauter Rods
*Golden Eeagle Sleeves (Machine Work)
*Custom ARP Head Studs
*Ferrea Racing Custom Retainers
*Ferrea Racing Custom Springs
*ACL Race Bearings
*Injected OEM Mounts (3M Window Weld)
*Custom Intake Manifold - by Gato Performance
*Thermal Gaskets
*GoPower Cam (still debating)
Transmission - (lets see till when it holds!)
*MFactory Helical LSD
*MFactory FD 4.678
*Clutch Masters 'Stage 4' 6 puck clutch
*Stainless Steel Clutch line
*Hybrid Racing Shifter Bushings
*Hybrid Racing Base Bushings
Forced Induction -
*Gato Performance R18 Turbo Kit
*Precision 5857 Journal Bearing Billet .63 A/R (Ceramic Coated)
*DEI T3 Turbo Blanket
*Tial 38mm vband
*Hondata 4bar Map Sensor
*Skunk2 76 mm Exhaust
*Stainless steel Turbo manifold, exhaust, Dumptube (Ceramic Coated)
*intercooler
***CMB TUNING***
Fuel System -
*255 Walbro Fuel Pump
*Jotech Fuel Return Kit
*Fuel Injecter Clinic 1000cc Injectors
*Custom Fuel Rail
*All fittings will be AN and Stainless steel Braided lines
Suspension/Brakes -
*Skunk2 Pro-C Coilovers (8k Front, 12k Rear)
*Full-Race Traction Balls
*Goodridge Stainless Steel Brake Lines
*ARP Extended Studs
*Hawk HPS Front
Up'ed the boost to 9 psi and results are as followed
Transmission
4Piston Racing - port and polish
World's First Sleeved R18A1 thanks to Golden Eagle!
420Coupe
Post by 420Coupe »
Slowly getting there...
420Coupe
Post by 420Coupe »
420Coupe
Post by 420Coupe »
420Coupe
Post by 420Coupe »
Gato Performance R18A1 Intake Manifold
420Coupe
Post by 420Coupe »
420Coupe
Post by 420Coupe »
420Coupe
Post by 420Coupe »
420Coupe
Post by 420Coupe »
