Upgrade to K-Pro III
Bard
Post by Bard »
Hello!
How can i upgrade TSX K-Pro dual harness ?
Re: Upgrade to K-Pro III
The KPro is the same in the dual adapter setup and any other ECU.
Use this form http://www.hondata.com/kprodatalogform.html and go through your dealer.
Keep in mind that the Dual harness is no longer supported by Hondata.
Bard
Post by Bard »
Spunkster wrote:Keep in mind that the Dual harness is no longer supported by Hondata.
You see, i can not upgrade to flashpro because in my location there is no "dealer" that can flash immo, there is no dealer around in 3000 miles also, or might more.
Btw, not supported does not mean it can not be upgraded?
