which input should i use?
newpassport
Post by newpassport »
My ecu is kpro3 for 05~06 rsx
The AFR gauge is innovate MTXL.
Should i use the eld pin or analog input to datalog and display afr?
which is the best?
thanks
Re: which input should i use?
Any aftermarket wideband used can only be used for datalogging and display only. It will not work with lean protection. You can either use the wideband input selection in Optiosn settings, Wideband input, or you can use the analog inputs that are part of the K-Pro3.
