Why is wrong to show the fuel consumption?
Nike
Post by Nike »
- FlashPro SN.: FP-R18-US-50042
- FlashPro Manager version : 1.3.2.0
- Vehicle : Honda Civic 1.8 Americas
- ECU: 37820-RNA-A07
- Problem:
Compressor is installed Rotrex_C30-84. Fuel injectors DEATSCH werks 600cc. The program entered: Calibtation-Fuel: Stok Injector Size = 185cc, Current Injector Size = 440cc. Setting made ​​to stand on the MAF.
Actual fuel consumption is 3 times larger than the on-board computer displays. You can in the next release to fix this error?
Thanks, best regards.
mabo
Re: Why is wrong to show the fuel consumption?
Post by mabo »
I have TSX and the same problem after i changed 310cc to 410cc, wrong mpg on dash, less then real consumption. Seems like the difference is 25-30% in my case.
The Civic R18 does not have an instant fuel economy display.
Nike
Post by Nike »
Hondata wrote:The Civic R18 does not have an instant fuel economy display.
1. I have installed a display with the European version, which shows the fuel consumption (with the stock fuel injectors showed the correct).
2. Any program that reads the fuel connector OBD-II, also shows the wrong fuel. Moreover, the testimony of the program are wrong as many times how many times greater than stock injectors new injector.
3. Europen 8th Civic TypeR also shows the consumption of improperly installing larger injectors (from my friends).
4.
mabo wrote:I have TSX and the same problem after i changed 310cc to 410cc, wrong mpg on dash, less then real consumption. Seems like the difference is 25-30% in my case.
410/310=1.32 or 32%
This problem is not just Civic R18.
You can fix it in newer versions?
1. We can add the injector use for fuel economy to the R18, like the Euro CTR, which may fix the problem.
2. After market OBDII scan tools don't use the ECU to dash fuel economy data; they just use the AFM and/or MAP. Normally you can calibrate them.
3. Euro CTR works ok.
4. TSX also works ok.
Nike
Post by Nike »
Hondata wrote:1. We can add the injector use for fuel economy to the R18, like the Euro CTR, which may fix the problem.
Ок, thanks)
mabo
Post by mabo »
Are you shure it works fine for CL9 ? I have same problem with bigger injectors. Wrong fuel economy on dash.
TSX != CL9 in this context.
mabo
Post by mabo »
Wont work for me correctly. 310cc injectors - 11.5-12 liter \ 100 km = true mpg if i measure by my fuel tank , 410cc - 8.5-9.5 \ 100 on the dash.
Nike
Post by Nike »
When you can do it? Manager 1.3.3 doesn`t have the injector use for fuel economy.
Thanks.
Nike
Post by Nike »
To Hondata:
When you can do it?
Thanks.
mabo
Post by mabo »
Hondata wrote:TSX != CL9 in this context.
So , if its not a TSX ( i have CL9 Accord ) it will not show correct fuel economy ?
