pwm not working!!!
skullbasher
pwm not working!!!
Post by skullbasher »
the pwm value says 99 percent since i have the quickspool to spool quickly to 16psi which i have done before but now something has been going wrong. ever since i think i downloaded this version i have beeen having this problem. i hvae tried chanig frequency, quick spool values and everything almost under the boost parameters but i cant fix it.
i use to be able to build 20psi with 70 percent duty cycle with my tru boost aem controlller, and now that i have it hooked it up to the s300 it doesnt want to go anywhere near that. a couple weeks ago before i downloaded the newest version i was boosting 16 psi at 60pwm which was good and now with the latest 2.1 version i cant seem to make more that 11 and i tried messing with the quickspool values to bring it up but as you can see it didnt work. it hit 99 percent and it stayed there cuz i couldnt passs the quickpool value but i ddint keep rising in boost. i already set the activation in negative vaccumm to check if the ecu is powering it and i do hear and feel clicking from the solenoid. what could be it!! my bov does not appear to sound like its leaking and the wastegate holds boost when the controller is turned off at 7psi
Re: pwm not working!!!
Can you post the calibration?
