Quick Spool
magnEsium
Quick Spool
Post by magnEsium »
Hondata,
I have a user who is using the quick spool option set for 16psi and full (high)boost is about 18-19psi.
However, wouldn't this be rendered useless with a low boost switch since there is only one set of options?
For example, low boost the user wants to run say 10psi. The above quick spool option no longer can be set because the quick spool will want to hold the controller at 100% until 16psi is achieved.
Thoughts?
Thanks,
magnEsium Tuning
http://www.magtuning.com
Re: Quick Spool
Just use the lower settings for the quick spool for both the high and low boost.
