K-Pro PRA O2 Sensor desable
Fuzzy
Post by Fuzzy »
Hi i have a Honda CRX 1988 with K20A (DC5) engine and i did the engine wiring by myself, the car works fine and i tuned the car with the wideband, now i want to desable the O2 sensor cause i dont have any, and after a whilethe engine runing the K-Pro keeps showing the DTC P0132 high voltage error... how can i solve this? I try to look if anyone had this problem but i didin´t find any help. What i see is, if i had a PRB i could disable the O2 response but on my PRA i dont know how.
Re: K-Pro PRA O2 Sensor desable
playasyougo
Post by playasyougo »
http://www.hondata.com/forum/viewtopic.php?f=12&t=14305
Granted i was using a PRA ECU but the above fixed my P0132 DTC code for good.
Fuzzy
Post by Fuzzy »
Hi change the close loop for secondary O2 and problem solved.
