Hondata/Comptech reflash?
05K20Z1
Post by 05K20Z1 »
I recently bought a reflashed ECU for an 05 RSX Type S. I'm a little confused and had some questions. It says it's been reflashed for a vehicle with a comptech supercharger, will this work without a super charger and basic bolt ons? Here is the info on the ECU
37820-PRB-A13
1589-301904
The sticker on the faceplate has this info
Supercharger Serial # DJ26441
Supercharger Kit # 350-029
Mod List: Injen long ram intake, comptech header, Apexi cat-back
Hondata info
Installer: Matt Date: 1/6/09
Reflash/Board Serial #: K20Z1-MT Comptech
Re-Flash map #: K20Z1-MT Comptech
SN#10118 Blower # DJ26441
Re: Hondata/Comptech reflash?
If you remove the supercharger then the reflash is not going to be suitable for your engine.
05K20Z1
Post by 05K20Z1 »
Ok, the guy I bought it from claims that it was comptech reflash, then it was sent to you guys to be reflashed again for just basic bolt ons. Is this possible for Hondata to overwrite the Comptech reflash?
It is $200 to change to a different reflash.
