S300 V2 analog inputs for Aem wideband
Wego5
Post by Wego5 »
I can't seem to find any definite clarification. I plan on using the analog pigtail, do I just plug it into the S300 board and connect to the A0 wire? Do I need to re-ground one of the two ground wires on the pigtail?
Any help is appreciated
Re: S300 V2 analog inputs for Aem wideband
http://www.hondata.com/help/smanager/analog_wiring.htm
Wire the signal to the input you wish to use. You probably do not need to wire any additional groun d to the AEM other than the standard power and ground.
Presicion6266
Post by Presicion6266 »
Hey Spunkster dose this wiring apply same on the aem 30-4900 witch is the fail safe & AFR/Boost in one.
I just need to know witch wire goes where.
Those analog inputs are for datalogging only. You cannot run closed loop from them or use any lean protection.
abdullahjamo
Post by abdullahjamo »
does that mean that its only of use when the s300 is hooked up to a laptop? if so then how do I hook up a AEM 30-4100 to the ECU for real? and should the analog input be removed while driving normally? could it hurt the ECU?
You do not have to disconnect the analog inputs when driving.
Basic details on wiring a wideband can be found at: http://www.hondata.com/techplxwiring.html
Just susbstitute the correct wire colors for the wideband you have.
