Bug: KManager 3.1.2.0 crashes when using "[]" in notes
coolchip
Post by coolchip »
Hello,
at version 3.1.1.0 I had saved a few notes in my map. It looks like the attached bitmap.
Then I installed version 3.1.2.0 and saved the same map with the same notes.
After that, everytime I try to open the map nothing happens or KManagers crashes. A look into the map file shows how. I think the square brackets should not be used in the notes.
*EDIT*
Perhaps the problem is the carrige return and not the brackets.
Re: Bug: KManager 3.1.2.0 crashes when using "[]" in notes
This has been fixed for the next release. Thanks for pointing it out.
