reads ignition off
aleccharles
reads ignition off
Post by aleccharles »
37820-PRB-A08
2068-801635
i got my ecu back and i installed kmanager and the drivers no problem i plugged the ecu in and the fuel pump primed and the car started and ran good but kmanager says drivers installed and online ignition off....so i turned the engine off and turned the ignition on with out starting it and this time the fuel pump didnt prime and it still says ignition off all of my fuses are good and my wiring is done right im not sure whats wrong...........
Re: reads ignition off
What vehicle is this in? Have you tried the ECU in a known working vehilce that has K-Pro?
aleccharles
its in a 2000 integra ls and unfortunately i kinda live in the sticks and i have no way of testing it on a different vehice when i have the ecu plugged in the red light is flashing but the green on isnt if that helps any
aleccharles
It is a itr k20a I am using a hybrid racing sub harness that I have already checked and is wired correctly and I am using a rywire engine harness and the grounds are all ok
Since this is an engine swap there is a very high chance that this is sa wiring problem. So there is either a wiring problem that is corruntly causing the ECU to no show ignition on, or thta ECU has been damaged by a wiring fault in the vehicle. Either way you must try the ECU in a working car to see if the ECU is damaged or not, then you need to resolve the wiring fault. If the fault is not resolved and you replace the ECU, it will be damaged as well. You may should contact Hybrid Racing or Rywire about this.
K20egcw
Post by K20egcw »
I'm having the same problem. The car starts up, and runs great on a stock PRC ECU. Once I plug in Kpro (PRB), it reads "Ignitions Off". There is another guy on K20a.org that's having the same problem as well. Tomorrow I'm going to try to uninstall and reinstall Kmanager and see if that fixes it
aleccharles
i solved my problem by moving my wiring harness ground i thought it was grounded fine where it was but apparently not haha i just moved it and it started right up
K20egcw
Post by K20egcw »
aleccharles wrote:i solved my problem by moving my wiring harness ground i thought it was grounded fine where it was but apparently not haha i just moved it and it started right up
Where did you move it to, if you dont mind me asking? Thanks
aleccharles
it was right on top of the valve cover where the stock harness was grounded almost right in the middle of the valve cover
