Reflash or Flashpro which would I need?
1niceK20
Post by 1niceK20 »
I have 09 Si still stock, but I have the skunk2 72mm manifold
and tb with takeda intake sitting at home. If I install them
and let the ecu cycle a couple of times to let the maf adjust
and get the Reflash will this have it running good, Or should
I just keep saving for Flashpro.
Re: Reflash or Flashpro which would I need?
You will need the FlashPro so you can properly tune for this.
