Second O2 Sensor Disable Function
FlashPro questions & answers specific to the 2010 CR-Z (US, Euro & Asia)
Jamez100189
Post by Jamez100189 »
Hi,
I have recently installed a decatted extractor/manifold and decatted exhaust on my CR-Z which is bringing up the expected CEL light with code P04020, which I thought i'd be able to remedy the same as usual using the FlashPro, however when I came to check the box, it wasn't there.
In the FAQs at the bottom of the CR-Z FlashPro Page on your website it states that the FlashPro can be used to disable the 2nd O2 Sensor, however I fail to see how at the moment.
Can you please shed some light on this issue.
Many thanks,
James.
-------SpoonSportsEurope.net-------
Re: Second O2 Sensor Disable Function
The FlashPro page for the CRZ had the FAQ from the Civic Si. We've updated the CRZ page with the correct FAQ.
Jamez100189
Ok, I appreciate the quick response,
So you're saying there is no facility to disable the secondary O2 sensor at present then?
Thanks.
Not at the moment.
Jamez100189
Ok, thanks.
