scaling boost collumns
boosted_z3
Post by boosted_z3 »
Hey guys, I've tried searching but I can't find the answer. I'm looking to run more than 17psi which the collumns are scaled to. How do I get the collumns to go up to 20psi? Thanks in advance.
Re: scaling boost collumns
boosted_z3
Only question I have about the edit values option....if I edit the last collumn to say 20psi instead of 17.7, how do I tune from the second last collumn to that new 20psi collumn? Thee change would go from 15psi collumn right to 20. Instead of having another collumn in between them. Would be much easier if you could just add more collumns and leave the tune you have on the original ones.
It interpolates between the columns. You do not need a column between them.
