Fuel table #s max out at less than 50% duty cycle
wiggum80
Post by wiggum80 »
I was tuning a boosted k24 with Injector clinic 2000cc injectors. I maxed out the fuel numbers really early in the tune so I turned up the overall fuel trim to 100% and started over. I successfully tuned the car to 24 psi. The duty cycle was around 47% and the # in that cell was almost 20000 (max) How can I get full use of these injectors? Also my second question was; is there only 16 columns for the load index? I was reading up on showing the 5 bar maps, is it true I have to rescale within the 16 columns?
Re: Fuel table #s max out at less than 50% duty cycle
Yes you must rescale within the 16 columns.
Start by changing the Injector size, then get it close using the fuel trim, then fine tune using the tables.
