Fuel Duty cycle % vs Fuel map
Martgsr
Post by Martgsr »
I have a question about fuel map and the duty cycle %.
How can you see the fuel map in duty cycle % ?
Or can you see the value from fuel map in the datalog ?
Because it's hard to see what value in fuel map has been modified vs the logs.
Sometime i'm not sure if i have already modified the fuel map to readjust vs my af-ratio from the log.
So i can't compare the duty % with my fuel map table.
thank you
Re: Fuel Duty cycle % vs Fuel map
You cannot see the fuel maps in duty cycle %.
Use the map tracing to see where it is reading when looking at your datalogs.
Martgsr
Post by Martgsr »
Spunkster wrote:You cannot see the fuel maps in duty cycle %.
I"m using that very nice feature already. But since i'm doing that part time, if i'm looking the datalogs next week, i may have forgot if i already did some change to those particular fuel cell since i cannot compare the fuel map with the duty cycle % ?
