K24/K20 Map
its_ish
K24/K20 Map
Post by its_ish »
Hi, I need a map for the below set up so that I can drive the car to the tuners.
K24 block with 12:5 CP Pistons and standard rods
K20 head with Spoon cams and OBX Valves and retainers
DC5 K20 Type R injectors
T1R Exhaust Manifold
2.5" Exhaust system
RBC manifols
Spoon 70mm throttle body
Please email me at israel@jaycar.com.au
Thanks!
its_ish
Re: K24/K20 Map
Post by its_ish »
whats the turnaround time on map request in this forum?
Re: K24/K20 Map
its_ish
Re: K24/K20 Map
Post by its_ish »
I have and read the post and am back here...
There are no K24/K20 base maps available in the KManager that is close to my requirements.
I would've thought that Hondata would have hundreds, if not thousands of calibrations
from your database of tuners from around the world that is close to my engine set up
specifications.
05typeR
Re: K24/K20 Map
Post by 05typeR »
Hi mate,
Since you only need to get by your tuner(s) I would suggest adding about 5-10% more fuel and decreasing the ign a few degrees on a map for your car/motor
if you have flash mil with knock enable and a AFR gauge keep looking at these.
tomzauto
Re: K24/K20 Map
Post by tomzauto »
i can def help you out, check out my site
tomzautotuning.com or email tomzauto@yahoo.com
