S300 +TDC
jdm97r
S300 +TDC
Post by jdm97r »
Hi,
I have a problem on my S300
I am checking the crank pulley with the timing light and I m finding 2deg btdc
I checked all timing marks and cam degree
When I add timing from the tables ,I can see the 16 deg on the pulley marks
Is there something I have to do in the calibration please?
Honda Integra R JDM CW
Honda Civic EF 9.91@152 ... Sold
Honda Integra R EUDM CW SFWD 9.34 @158
Re: S300 +TDC
Have you used the Set Timing function from the online menu?
http://www.hondata.com/help/smanager/se ... ase+timing
jdm97r
Re: S300 +TDC
Post by jdm97r »
Spunkster wrote:Have you used the Set Timing function from the online menu?
Yes already did that and still my timing is low
Re: S300 +TDC
Step by step, how are you setting the timing?
jdm97r
Re: S300 +TDC
Post by jdm97r »
Spunkster wrote:Step by step, how are you setting the timing?
I go online and click on set timing
Then I put the timing light on the crank pulley and check
Re: S300 +TDC
You then need to adjust the distributor to get the desired base timing.
jdm97r
Re: S300 +TDC
Post by jdm97r »
The distributor is all advanced already
Can it be that the cam has the distributor slot different from stock?
Re: S300 +TDC
you need to start by making sure that the cam gears are properly alligned when the crank is at TDC on Cyl1. Many factors can be at play here: head that has been machined, improperly ground cams, adjustable cam gears out of spec or not set correctly, mismatched timing belt for block and waterpump.
V-Spec race development
Re: S300 +TDC
Post by V-Spec race development »
Intake cam may be a bit retarded.
jdm97r
Re: S300 +TDC
Post by jdm97r »
I have ferrea intake cam and was told that it has 5 deg btdc off
I checked all timing marks,cam gears and everything.
Is there something to do to compensate that 5 deg off the cam,?
