Change to MAP based
stjimmy
Change to MAP based
Post by stjimmy »
Running Civic Si K20Z3 2008.
I imported her from USA.
Tunner here, in Korea mapped stock ECU.
I am trying to change this mapped ECU, which is MAF based to MAP using Hondata.
I dont want to waste another bucks to give away to tuner..
Is it possible to just import map from vehicle, and change it to MAP?
I will appreciate your answer.
Re: Change to MAP based
What is the serial number of hte FlashPro and from Help, about, what version of software are you using? Post your calibration.
stjimmy
Post by stjimmy »
Spunkster wrote:What is the serial number of hte FlashPro and from Help, about, what version of software are you using? Post your calibration.
I didnt installed yet, I am afraid that reflshed ECU data will lost..
FP-SI-US-11719
Using newst Flashpro 1.3.5 version.
Another question, when I unlock this flashpro, says return to stock ECU.
Does my reflashed ECU data(not used flashpro) will back when I unlock it?
Or Hondata Stock ECU data will goes in when I unlock?
My ECU is not stock, so I am worried...
Return to stock will return it completely to stock. Once you use a FlashPro you cannot get the reflash back.
You will have to load a calibration from the New Calibration button and make any changes then upload to the ECU. If you use an AFM calibration you can still tune it via MAP.
http://www.hondata.com/help/flashpro/fu ... %2Bdensity
