Datalog interferance
jdm97r
Post by jdm97r »
I have my S300 does not go online and the datalog does work also when the engine is running
When I turn my engine off,everything works normal
I use an M w pro 10 ignition and BKR9EIX plugs.
What else I can do to fix this problem?
Honda Integra R JDM CW
Honda Civic EF 9.91@152 ... Sold
Honda Integra R EUDM CW SFWD 9.34 @158
Re: Datalog interferance
The problem is caused by interference from the aftermarket ignition system. Where is it located?
jdm97r
Post by jdm97r »
It is located behind the rh headlamp and my car is rhd so ecu is on the lh
Try returning the ignition to stock, if that resoves the problem you know it was the aftermarket ignition system.
jdm97r
Post by jdm97r »
Yes but I need to fix the problem not to change the ignition
Step 1 is to see if the ignition is the problem as it is the most likely cause.
