Final Drive
dinoc
Final Drive
Post by dinoc »
Hi,
Will the Cruise Control and VSA still work with FlashPro if I change the Final Drive (putting a bigger one) ?
(regarding real speed , I'm planning to use a Dakota Digital SGI-5 to fix the speed with the new FD). I hope there is no interference with Flash Pro.
Euro Honda Accord CL9
Re: Final Drive
The use of FlashPro does not change any of the electronics in the vehicle nor the VSA operation. So the effect of changing the final drive and using a speed converter on the VSA, dash and cruise control is independent of the use of a FlashPro.
The question you probably should ask is whether you can change the ECU gear ratios using FlashPro for the ECU internal gear determination and cruise control. We have not tested this yet.
dinoc
Re: Final Drive
Post by dinoc »
Any plans to make this work ?
There are a lot of people out there running custom gears in their TSX-es.
I want to switch for custom gears but I don't want to loose the CC .
beaugus
Re: Final Drive
Post by beaugus »
+1 for this feature to be added to Flashpro. It's the very last outstanding issue to re-enable cruise control for us :-)
Zoro2006
Re: Final Drive
Post by Zoro2006 »
+1 would be nice feature for guys with PPG
Known as Vaikis_
